H/C/I lookin for 300rwhp
RE: H/C/I lookin for 300rwhp
he wants 300 rwhp, thats like 345 Horsepower, this aint gonna cut it.
The Ported GT 40 swap with your other mods, gets you around 240 rwhp, or like 280 actual HP at flywheel.
no way 240rwhp im tellin you i had stock heads and a cam make 220 your saying 280 fwhp so that means your claiming take a cobra port the heads, cam, better intake, tb and maf lt's is only gonna help from 245 to 280
To hit 300rwhp those GT40s need a professional port job (not someone on the tailgate of a pickup with a Dremel tool, someone with a flowbench)and a killer valve job along with the perfect cam and intake. If all supporting mods where there like tb, maf, injectors, exhaust, etc.and electric fan and water pump it would be close. Like I said the heads need to be killer. People have Trick Flow top end kits that don't hit 300rwhp. Gt40Ps are a good head but even with good porting they aren't going to be leaps and bounds better than a good name brand aftermarket aluminum head.
well I can understand that if I dont hit 300 im not going to be dissappointed but i think 240rwhp with ported gt40's and all the bolt on's is bad low like i said im looking for 300 if i hit 275 then so be it but there is nobody on here answered my question about what cam and what intake will perform the best with the given information to get me as close as possible to my goal
ORIGINAL: 91lx50udlose
so your saying that
ported gt40's
1.7rr
76mm maf
intake
cam
headers
tb
injectors
that it's IMPOSSIBLE to get close to 300
so your saying that
ported gt40's
1.7rr
76mm maf
intake
cam
headers
tb
injectors
http://videos.streetfire.net/video/7...210017f218.htm
thats a stock shortblock with gt40 irons/C/I bolt ons like 285 rwhp if you click his links he makes 291 on the next run when the transmission breaks
Steeda 18 wouldnt be a bad choice either would a 70mm tb with those heads, im big fan of tubular gt40 mainly because of looks but they perform pretty well on 302s when you port out the lower.
This seems like its going to be an enlightening thread. b/c im aiming for 280ish rwhp with a similar set up
GT-40 iron
TF Street Heat Intake
TFS1 cam
LTs
Prochamber
24lb injecters
I plan on Thumper porting the Heads and lower intake.
GT-40 iron
TFS1 cam
LTs
Prochamber
24lb injecters
