holley heads
holley heads
anyone have anything to say about them? might have found a set for some coin plus my 40s... i know that the exh ports are higher, will that be an issue for my exhaust at all? and i hear something about valves? wuts up there? are they 2.02I? should that be an issue>?
RE: holley heads
What up Dime? Hey I only have one thing to say about holley heads....stay away...I have a set ona 306 I built a while back....if the heads are the older holley's like 5+ years old....they suck ***....they use a specific guide plate thats wider than the norm....I called holley and talked all this crap and they are like we fixed them....geometry is correct now....you have do stupid things like lengthen your EGR cross over if you still have it? Its just a multitude of little things that suck ***.....your like WTF?
RE: holley heads
well, this has guideplates already, yes they are a little wierd, they have nylon inserts... i dont have a crossover tube anymore
im mostly concerned with the differant valve angle(18* instead of 20* i believe) and the higher exh ports
RE: holley heads
There should be a stamped # on the heads call Holly and get the specifics.....what nylon pieces areyou talkin about? Dude I'm trippin right now...that could be my issue with sloppy rockers.....they dont just run a guide plate alone like edy's and afr's? I know you have to lengthen pushrods for sure with them....stock wont work they pull and push stock ones all over the place and f em all up...mine ended up being 6.400....
about the higher exh. port? I wouldnt worry about that....just angels like the TFS has weird ones too right?
See this is the crap I'm talkin about.....its like dude...I'm just bitter when it comes to Holley heads....LOL
RE: holley heads
yea i dunno, im tempted to get them, but dont wanna give up my gt40s for these just to find out their not gonna work w. out flycutting the pistons and all kinds of effort
RE: holley heads
Yeah I hear ya....you know what sucks about them is nobody runs em....I came across mine for super cheap too....did a bunch of port work to em...then when came time to run em just issue after issue after issue....if I didnt have all this money into the port work I woulda got rid of em....are they on the guys car your getting them from is it running? Whats the deal?
RE: holley heads
no, he has a falcon, and he cant get them to fit w. the raised exh ports, its alot tighter in those cars... i know thats not a huge concern for me, ill make that work fine... im just concerned with ptv at this point... i CAN fly cut my pistons, but dont want to
