OK then this kit will be fine for you. As long as you dont go FI you shouldnt have a problem. If you do though you will not be able to run too much boost because you can blow the motor. If you are working on a budget then I suggest you go to the junk yard and look for the explorer 5.0 motors. I forgot exactly what years but I believe it is 96.5-98. Also buy yourself a port and polish kit and a set of junky crappy heads and learn to port on your own. Since your working on a budget I'm guessing you are going to be doing your own work and if you port your own heads and intake mani you should feel just right.
ya Already got that setup for the port and polish.Buying a 97 explorer upper and lower intake manifold tomorrow includes a 65 mm tb too thanks for the help.
