Carb spacer
RE: Carb spacer
ORIGINAL: 85stang1373
what does it do and is there any HP gains from it??
tb spacers on efi vehicles....do ABSOLUTELY NOTHING.
RE: Carb spacer
I would get it cause its not really that expensive but be sure that after you put it on that it will clear your hood. I have one on mine and it BARELY cleared with the 14x3 edelbrock air cleaner. I got the performer intake and carb also.
RE: Carb spacer
you wont be wasting your money.
get a phenolic spacer...helps ALOT with heatsoak into the carb,round 4 hole,or open plenum spacer..that choice is up to you.
but either way,dont listen to the EFI guy...its not all about the HP it makes,its about how it REALLY is proven to help atomize the fuel and distribute it more evenly,and god knows a carb'd sbf needs all the help it can get in that department.
RE: Carb spacer
Exactly, I ended up getting the aluminum spacer and I don't remember why but I think its because I couldn't find the one I wanted at the time in the phenolic. But go for it if you can find one.
RE: Carb spacer
i'd have to say the heat insulating trumps any power gains, hood clearance is usually the problem, and if you end up in a drop base aircleaner that sucks too cause its not a straight shot for the air to come into the cleaner and down in the carb
