fuel issue
fuel issue
ok I have read alittle on my problem.
My car would run for maybe a min and then die then it would either not start or do the same thing over again. I couldn't drive it so I started saving for parts. now when I try to start it, it wont even hum(power up) I just ordered a new pump because mine is a stock 18 year old one.
What could be causing this?
William
William
RE: fuel issue
It's worth checking the fuel pump relay. I'm not sure, but it should either be under the drivers seat, or in the engine bay on the passenger side strut tower/area. I can't remember which year is where. Sometimes they'll work, then heat up and shut off, cool down and work again. Just an easy thing to check before you pull the pump.
RE: fuel issue
is there more then one because the diagram I have shows one under the drivers seat and nected to the EEC. Befor all this happened my car had been missing really bad and getting cra*y gass millage. throwing a code that said max fuel # 65 or some 60 code in the key on test
RE: fuel issue
so why don't you do a fuel pressure test by getting a gauge and tap of the schredor valve on the fuel rail...it's not rocket science ya' know........after that go back to the connector on the tank and check power and ground.. it should light up briefly when switched on ..if it does.. system is okay and if you have no fuel pressure then it's bad pump
RE: fuel issue
ORIGINAL: mjr46
TfcCDR
09-14-2015 12:08 PM
zanemoseley
09-06-2015 12:58 PM
