MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   5.0L (1979-1995) Mustang (https://mustangforums.com/forum/5-0l-1979-1995-mustang-14/)
-   -   afr 165's or 185's? (https://mustangforums.com/forum/5-0l-1979-1995-mustang/408003-afr-165s-or-185s.html)
93StreetFox Feb 18, 2008 12:22 AM
afr 165's or 185's?
ive researched alot of heads and learned they were junk, so im just gonna save up for some afr's. which ones would be best to go with?
primetime5.0 Feb 18, 2008 12:24 AM
RE: afr 165's or 185's?
302?306?331?347?
67mustang302 Feb 18, 2008 12:27 AM
What do you want to do with the car?
93StreetFox Feb 18, 2008 12:29 AM
sorry its a 302, im just wanting to keep the bottom end stock, everythingtop endaftermarket, eventually run a smaller supercharger
67mustang302 Feb 18, 2008 12:43 AM
165's with the optional blower/nitrous exhaust port would work nicely. If you're not afraid to add some better rod bolts and turn some rpm, a cam and 185's would work nicely as well.
my77stang Feb 18, 2008 08:44 AM
why not look into the new edelbrock 170cc heads? they are supposed to flow as good as the 185's yet have a smaller runner. seems like a great "in between" head, maybe better (unless your going to hog out the 185's later)
68CSTANG Feb 18, 2008 11:58 AM
Where can you find these new 170cc Edelbrocks? I havent heard much about them.
5spd GT Feb 18, 2008 02:41 PM
AFR 165 for the stock pistons.
AFR 185 for aftermarket pistons.
I hate to see an AFR 185 head used on a stock bottomend with a camshaft "tailored" around the clearance.
With the "larger" heads, you are not going to see anything unless you have an intake to keep up with the potential.
For example, there is not need to have a 280 CFM head, if you have a 240 CFM intake sitting on top of it.
OneFine89Mustang Feb 18, 2008 03:10 PM
165
67mustang302 Feb 18, 2008 04:21 PM
You'd have to call Edelbrock about the new heads, they list the flow specs on their site, and they're listed as an option in the power package section, but that's it. They'd make excellent n/a power, and work well with a blower as well. If they have an optional larger exhaust port they'd be great for a blown setup.
© 2026 MH Sub I, LLC dba Internet Brands
