1994 mustang heads?
RE: 1994 mustang heads?
ORIGINAL: cougarfan088
will any heads for a sbf work with my 302? becasue some say they will only work up till a 1985 so...I was jw.
usually cases like this... require more information, like links.
Im not a dentist, so dont make me pull teeth!
you need to state what year heads you are looking at and what year block you want to mate them to..cause some combinations require steam holes drilled in the block on late model blocks to use early style heads
its the block from the 94 that is going to be a 331 stroker..
like these edelbrocks is what i was looking at.
http://store.summitracing.com/partde...p;autoview=sku
also, what is the difference between the regular performers and the RPM performers?
AFR 185's or 205's depending on the setup.
a good rule of thumb to start with are a head whose intake runners are at least 185, 195 and above depending on how wild the build is...afr , canfield and even the new edelbrock 170's are suppose to flow up there toalso having a head with a 2.02 intake valve is a good place to start for a stroker also
