oil pressure.. big problem!?!
RE: oil pressure.. big problem!?!
well i had the clutch done and the lower intake manifold gasket and the oil pan gasket so all together yeah it cost wuite a bit and i'd hate to have to pay twice for the oil pan to be taken off and put back on but thats what i get for not thinkin of replacing it in the first place.
yeah dude my oil pressure gauge s like at half way in the morning when cold but when it gets waremd up its in between halfway and 1/4 of the way... i work for my dad at his tranny shop so yeah i can do all labor for free... people tell me that he motor is going but i dunno..
ORIGINAL: posnick
if you pressure drops that much when its warm chances are its the bearings. its extremley rare that a oil pump goes
get it checked with mechanical guage befor you do anething to know for shure . with a new oil swich it read good for a while then it started acting up again . get a mechanical guage reading first
no the pressure doesn't drop by much at all, it is at the a in normal then when warm at idle it at the bottom part of the l, the temp guage is at about 3/4 is what i was refering to in my post earlier, I'm thinkin that they didn't change the pick up tube when they replace the oil pan gasket so it may be clogged up or the pump is going, i dont want to even consider it being bearings.
ORIGINAL: 88GT40
if you pay them to drop the pan, get them to pull a main cap and inspect the bearings also, bet they will tell you they are worn out!
