new to tunning need help
i have a 93 gt mostly stock but not for long and i want to change to a lightning maf what do i need to do that. also i want to get rid of the egr system, what is the best ecm to run and what is all this talk about the tweecer and pms systems
RE: new to tunning need help
PMS won't do you much good for running an LMAF... you could make it work, but it won't be easy... PMS has recommended against it.
With the tweecer upgrading to the LMAF is fairly easy.
Do you have future mods planned that will require a 90mm MAF meter?
Nothing against the LMAF, but a stock motor barely needs a 55mm meter...
jason
jason
ORIGINAL: mjr46
...and when you do have mods that warrant a maf change....you need to match it to injectors used
With the tweecer, you can purchase almost any MAF meter and have it setup in a matter of minutes.
Also, injectors could be changed without having to buy a new MAF meter.
In my opinion...
If tuning is in the long term plan, then the tuning package should be one of the first things purchased.
This would allow the user to build tuning skills with a lightly modified car,
AND
eliminate some of the need to buy parts twice.
Just my opinion though...
jason
A9P, A9L, those are the common ones and there is a lot of info out there on how to tune them, X3Z is the cobra one that uses 24 lb injectors but I run 24s on an A9P that I tuned(with help from dudestang)so I don't see the need for the more expensive cobra ecu.
Matt
Matt
