Off set rack bushings or not
Old 02-22-2008, 07:41 AM
03Mach69Mach
03Mach69Mach's Avatar
Default Off set rack bushings or not
Replacing the power rack & pinion and have differing opinions on whether to use off set bushings or. I have the Ford Racing B springs(Lowered .75" front & .5" rear) on the car. Replacing rack, tie rods and bushings. Search online has people saying that they do & don't help. Curious if anyone is runningsomething similiar. 1988 Convertible 5.0. Thanks
03Mach69Mach is offline
Old 02-22-2008, 08:05 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: Off set rack bushings or not
i have em
AdderMk2 is offline
Old 02-22-2008, 09:48 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if your car is lowered it'd help out with the geometry better to get the tir rod assembly back at the right angle
mjr46 is offline
Old 02-22-2008, 10:15 AM
03Mach69Mach
So the rack/tie rod should be level with the ground?
Old 02-22-2008, 10:59 AM
mjr46
mjr46's Avatar
not so much level but when you lower the car it forces the tie rods to angle up in the air....getting it as close to level as possible would be ideal
mjr46 is offline
Old 02-24-2008, 01:39 AM
Blck92GT
Blck92GT's Avatar
ORIGINAL: 03Mach69Mach
The install manual for my MM bumpsteer kit said you want the rod parallel with the control arm
Blck92GT is offline
Old 02-24-2008, 06:28 AM
TBird232ci
TBird232ci's Avatar
ORIGINAL: Blck92GT
Correct. You want the tie rod end to be parallel with the control arm.
Offset rack bushings can actually cause bumpsteer, rather than prevent it.
TBird232ci is offline
Old 02-24-2008, 08:41 AM
stang8689
stang8689's Avatar
I have them on mine too, but you only lowered the front 3/4" so its close
stang8689 is offline
Old 02-24-2008, 10:14 AM
CantStopTheFox...
CantStopTheFox...'s Avatar
I bought them when I installed my Eibach Pro-Kits.........drove it for a while, realized everything was fine so Inever installed them
CantStopTheFox... is offline
GimpyHSHS
19
12-19-2023 01:12 PM
TCStangerv6
10-11-2015 05:57 PM
Explosive
10-02-2015 07:45 AM
guitarman376
09-30-2015 05:54 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: Off set rack bushings or not
