gt40 heads
gt40 heads
i have a chance to get a set of gt40 heads off a 95 explorer..my question is this could be a cheap way to get a little more pep then using these stock heads what all needs to be done to make these work..does a machine shop have to port and polish them as well or can they be cleaned up and instalkled how they are..
thank you
thank you
RE: gt40 heads
simple answer yes ..they will be better than stock...long answer...u could probably get away with just bolting them on...but its best to have a shop check, clean them as well as if u get them p+p you will see better gains...
RE: gt40 heads
agreed
yes you can just put them on, but for the effort ? probably not worth it.
a little port work will double your gain, port and polish the exhaust, smooth out the intakes and deck them a bit + comp valve job
