egr drama
egr drama
ok im back been in the desert for a few and now its time to finish my baby but i have a question.
I have replaced almost everything I put a adustable fuel regulator with a gauge, and a 75mm throttle body and EGR plate, Trick Flow heat top end and the plate wont clear the regulator i have prob 1\2 gap before it will sit flush on the intake, its hitting on what i think is the EGR valve that bolts on the back of the plate, what do i do can i take it off and block it off or can i moddify the valve on the hush if not noticable, or affecting the valve.
thanks for any help and ill deff be posting back now that im back thanks again
RE: egr drama
Do they make spacers for throttle bodies and if so will it make it run rough. Ive been looking around at other posts and everybody seems to say diff stuff like you can just block it off or you cant so i just need someone to say i can or cant block it off,id like to start it for the first time this weekend. thanks everybody
ShaneB26154
35
03-04-2021 04:05 AM
TfcCDR
09-14-2015 12:08 PM
