fuel pump powerless
RE: fuel pump powerless
Leave the jumper wire to ground installed at the VIP connector, and check that the FP relay "clicks" everytime the key is turned to IGN ON...... if it does, and no pwer is present at the output wire to the inertia switch/fuel pump....... you may have a problem on the "always hot" power supply wire......
[IMG]local://upfiles/27355/AA6B8625CFF5471E8C43E51AE76C0B62.jpg[/IMG]
Ok here it is.
With FP Trigger grounded, the relay did not click. I checked the wires and this is how it went.
DG/ YEL -POWER
RD/BLK -POWER
TAN/LtGR -NO POWER
PNK/BLK -NO POWER
This was all done with the FP Trigger grounded and the key in the run position. I jumped the Pnk/BLK with the DG/YEL and the pump came on.So there isnt a short between the relay to pump.
DG/ YEL -POWER
RD/BLK -POWER
TAN/LtGR -NO POWER
PNK/BLK -NO POWER
From the readings you took w/out and with the FP trigger terminal grounded.......
and....
Looks like that relay is kaput..... the ground pulse is reaching the FP relay coil, and is still not switching the power from the DG/YEL terminal to the PNK/BLK terminal.... and you can't tell it is "clicking" = activating..... which should, based on the results above.
fuel pump relay
green/yellow-power on ignition on/and off
tan- power on ignition on only
red/bl- power on ignition on only
pink/bl-no powere ignition on/and off
ORIGINAL: littlebluelx
DG/ YEL -POWER
RD/BLK -POWER
TAN/LtGR -NO POWER
PNK/BLK -NO POWER
DG/ YEL -POWER
RD/BLK -POWER
TAN/LtGR -NO POWER
PNK/BLK -NO POWER
So I just need to replace this relay again? now what would cause both the stock relay to fail and this one?
Also befor my car was throwing 65 I think in the KOEO test and wouldn't run long enough for me to test the KOER I would run rich and miss fire. Would the relay going bad of caused this or a pump problem.
I have replaced every sensor or tested in the last two months. So people are telling me my cpu is gone. Any help Joe
Don't you mean code 66?..... if so, there's a problem with the MAF circuit..... which will not allow to run a KOER self-test. To ID the CPU as defective, you should go over the elimination process (=diagnose)...... this will prevent you keep on throwing $$$ at the problem w/out being sure the new parts will fix it. Just a thought.
Ok so I replaced the FP relay. and still nothing this is with the FP Trigger grounded.I also put in my spare cpu. and the code was something like "fuel preamiter max, Pressure regulator" I need this running so what will I hurt by just running a power wire from ignition controled aux fuse box. to the Pink/black fuel pump wire.
[IMG]local://upfiles/27355/E79DC3640A794375BE9132718CFEB0F7.jpg[/IMG]
