Vortech V1 S-Trim Kit. Any opinions?
RE: Vortech V1 S-Trim Kit. Any opinions?
Yeah don't think the fox kit will work for you. Hopefully its for the sn95 mustang. As far as additional upgrades if you stick with the stock pulley you shouldn't need to upgrade anything. The kit comes with a fmu that boosts the fuel pressure a bit to help deliver extra fuel. If you go with a bigger crank pulley or smaller supercharger pulley you will need a bypass valve fuel pump upgrade as well as bigger injectors that either a new mass air sensor calibrated for those inectors or have the stock unit recalibrated.
the head unit will, it is the bracketry that you will need to get replaced, i believe vortech will sell you the apporpriate bracket for the car....
Kryckter
07-09-2004 07:49 PM
