should i got back to sd mass air problems
RE: should i got back to sd mass air problems
Did you unhook your MAP/BAP sensor from vacuum source when you converted? It should be unhooked and left open to work with the MAF. Also check the ground at the back of the motor on the drivers side cylinder head to see if it is connected or loose. It is the ground for the injector harness but the O2 ground is there as well. Does the car run rich? The stalling sounds like a IAC problem, but the popping may be timing or a rich condition.
if anything the car is running lean and the grounds are all good i just put the motor in last week and yesterday i drove it all day and it dint pop and only stalled twice instead of every stop and the map is done properly
ORIGINAL: birdman076
it sounds like your O2 sensors are going bad to me. i just checked mine today and found that they were bad. The way to check them is to unplug them and start the car and if the car runs better then your problem is the O2 sensors. i was have that same problem with the beginning startup but as soon as it warmed up it was fine. i hop that helps
all have to look into to that do you unplug them when its warm or cold?
ORIGINAL: stanglx2002
ShaneB26154
35
03-04-2021 04:05 AM
