Small problem with new intake install
i just got done installing my new Trick Flow intake on my 95' GT and i have one small issue that i was hopeing someone could help me out with. the fan isn't kicking on when the engine gets hot. i was thinking maybe the temp sensor is bad but what do you all think? could it be something worse? please help
RE: Small problem with new intake install
did you forget to plug in the ECT sensor?? double check to make sure you have it plugged in and the connection is good.
also double check the coolant level in the radiator with the engine cold to make sure it is full. if not, start the engine with the cap off and let it run until it warms up and then slowly add coolant until the radiator is full, then replace the cap.
