Holley 4bbl to C4 kickdown question
I have a Holley 650 carb and I do not have a kickdown linkage going to my C4. I was wondering a couple things. first, where exactly on the carb and tranny respectively is the linkage supposed to attach. Also, is there any place I could buy one, or a way I could make one myself. (I'm pretty good and pullin a McGiver) Thanks for your help!
RE: Holley 4bbl to C4 kickdown question
I know it's not absolutely necessary, but the tranny doesn't seem to want to downshift as is. I can do it manually if I want, but kinda wanted to make it work like it's supposed to. ;-)
Go to summit's website and get a Lokar Kickdown cable. There SHOULD be a lever on the same shaft as the shifter lever on the trans. And I think the Lokar piece comes with the stuff to link it to the carb. You should get one so you don't burn up the trans.
Daddys Girls GTs
09-14-2015 08:46 PM
