need help with blown 306 ???
i own a 88 mustang GT convertable. i have a forged 306 on the stand in theworks... i also have a intake and heads off a 97 mountaineer thanks to my wife.a e-303 cam 1.6 rollers MAC shortys and a cpu from a 89 GT 5 speed car. i have aprox. 9.0 compression i also have a paxton ns 2000 with 7-8psi. this is where i need y'alls help.do i need a MSD box?? if so what kind?what size injectors should i run??what sizeMAFshould i use. and thottle body. as you may know i have a speed density car. do you know of any thing else i will need for that swap. i also have a3.73's with a stock tranny i know that won't last but other than that do you think this is a respectable street car/driver? thank you for your responce .
RE: need help with blown 306 ???
No you dont NEED the msd but it will help. Im still running the stock ignition with a blaster coill and i have no problems with spark. You will need 42lb injectors and if you have a FMU pull it out, you will need to get it tuned and they will sort the fuel issues out there. AS for the TB id go 70mm maybe 75 if you plan on upping the boost/getting bigger heads down the road. And yes its def a respectable driver, you should be putting down around 375RWHP which will most likely take care of 90% of the challenges you will get on the street
You dont "need" a box i just got a coil on my boosted car injectors id go with 42's and lightning maf at least thats what im running on mine but u need to get it tuned with it tb get a 75 but u will need to bore out the intake where it bolts up too and good luck trying to boost it on speed density im prty sure u will just about half to change it over to mass air.
stangin1996gt
09-21-2015 11:01 AM
Daddys Girls GTs
09-14-2015 08:46 PM
