how much hp
how much hp
hi everyone ... this winter a intall a lot of piece on my car and i want to know how much hp i will have when the summe will be back... so i put ... trick flow stage 1 cam..twisted wedge head...24 lbs injector...190lph fuel pump..gt-40 intake...70mm TB..75mm MAF...pulley...smog pump eliminator...3/8' intake spacer.. king cobra clutch...bbk shortie header...h pipe... magnaflow cat back.. trick flow timing chain.. tick flow chromoly 6.7' puch rod...comp cam roller rocker..fuel pressure regulator...k&n..accel ignition with ford racing 9mm wire ...stock block and that sit
now my timing is 12 degree.. do you think his perfect.. if not what is the best timing for this setup???
thanks
thanks
RE: how much hp
i think my block is in perfect shape ... last years i got all the piece a said without head..push rod..roller rocker ...timing chain... cam and i have 240 rwhp and 275 rwtq..
for the 6.700 push rod i take this part for the trick flow kit and i start the engine and everything look good ..
RE: how much hp
ORIGINAL: js89red
I would expect you to be in the 285-305 range depending on the tune and the dyno. Your pushrod length is ok.
