bangin 3rd
RE: bangin 3rd
Iv got the same problem , except mine only does it the first few times of the day. I kno how you feel though... you can but a new t5 tranny for about 1600 canadian, or you can it rebuilt , which im researching iv gotten quoats from 500 to 800
RE: bangin 3rd
All Forums >> [Ford Mustang Tech] >> 5.0L Mustang >> bangin 3rd
RE: bangin 3rd
depends on how high tech you wanna get, and some rebuild kits dont even come with the synchros , the parts you need. ivv seen them for 200, or 450 , and im assuming for 450 the synchros come with it. The main thing is the labour, i hear there tuff and hard to do on your own.
RE: bangin 3rd
ORIGINAL: Tims 88GT
do you have the stops on your shifter set right? it just keeps you from going to far, and if you do, maby you need a new clutch cable, or like everyone says maby the syncro has gone bad
RE: bangin 3rd
can some1 tell me a good place to find rebuild kits, i dont wanna buy an adjustable clutch quandriant, then that not be it and need a rebuild, but i dont wanna rebuild it when i only need and adjustable quadriant, its so hard to know and decide
RE: bangin 3rd
it says in your sig that you have a steeda tri-ax shifter, if you take off the boot around the shifter their should be a bolt infront and behing the shift handle with nuts on them, you adjust them so it gose in gear but when you bang gears it hits the bolt, i dunno how the steeda tri-ax shifter is but that is how my PRO 5.0 is
