I_WANT_5LUGS!
I_WANT_5LUGS!
Any1 know if i could fit some 17/9 bullits on my pony with this kit?
http://www.latemodelrestoration.com/...1&comp=LRS
RE: I_WANT_5LUGS!
www.sn95brakes.com All brake and 5 lug upgrade info you will ever need, And you can upgrade for way cheaper than that kit too.
RE: I_WANT_5LUGS!
ok, so from what i was reading i will need 94-95 spindles from a v6 or gt .front rotors, hubs, and calipers. and for the back i would need...? dont really know..? will i need ranger axles and disc brake setup from a94+ stang?
RE: I_WANT_5LUGS!
ORIGINAL: bzlover
RE: I_WANT_5LUGS!
ORIGINAL: AdderMk2
no, they wont fit over the hub
Here's what I did.
I used a 3/8" spacer, bought shoulder style lug nuts that reach into the wheel to grab more thread, mashed my dustcap flat and modified the center cap so it would all work. It looks great and there have been no problems w/ the way it was done.
RE: I_WANT_5LUGS!
You could use the ranger axles with the sn95 brakes but you will need to buy the specialty brakets that they make for the cobra kit cars which are slightly $$ but will allow you to keep the same track width in the back. I can't remember the company who makes these but I am sure someone does. You could always go sn95 dicks in the front and use the ranger axles and drums in the back, This will give you 5 lug and a good foundation for future brake upgrades while allowing you to run almost any later model 5 lug mustang wheel.
