MM panhard bar and torque arm
RE: MM panhard bar and torque arm
mjr what style bushings do they have? i just recently got them new w/ my parts car and i am not sure on the style of bushing. is it ploy or rubber? and i liek the idea of greaseable bushings
I can't remember..car is still at work finishing a few ods and ends.....but if I remember right it was sort of like polyurethene??.....their quiet though..cause I keep 'em greased
lol i heard that the poly bushings on the uppers were a no no cuz they cause binding or something... idk what i should do..
do you think i should just put the lowers on and keep the stock uppers or just put them both on?
i have a mostly MM setup onmy 90 LX.
rear lower control arms, rectangular full lenght subframe connectors, adjustable rear sway bar, panhard bar, torque arm & coil overs (with Bilstines), tubular A arms, CC plates and bump stop.
if you call MM they will tell you what you have to have and what you should do. NO GUESSING.
i built mine a little at a time, but i always called their tech and ask a hundred questions before i spent my $$$$. this stuff cost too much to find out what you have doesn't work well with something you just bought. i am very happy with the results. i built it for track work, but it is a kick at the drags too.
ORIGINAL: nacanitihs
what did you use for the housing eyelet? cuz that bushing doesnt come w/ the control arms correct? should i use what is on there already or go buy new replacements? or what?
sry for jacking the thread btw.. i want to get the panhard bar too but thats just not in the budget currently..
after this suspension install the motor is next.
I still ahve the stock bushings in there....I've read many articles and seen on Horsepower tv where they have gotten better results by doing such..... although I soon may replace my stock ones as they are kinda old with a new set of stock ones
