tranny popping out of gear
Old 03-10-2008, 07:47 PM
dzornes95
dzornes95's Avatar
Default tranny popping out of gear
for my buddy...first start up put in drive take off and it pops out of gear then pops back in..aod help .. i know you can help mjr46 ..he has a 94 gt 5.0 ho
dzornes95 is offline
Old 03-10-2008, 08:08 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: tranny popping out of gear
Aod pops out of gear??? like how?? rpm's rev and then a clunk then car moves?? or shifter physically pops up to nuetral?? little more info needed here
mjr46 is offline
Old 03-10-2008, 08:12 PM
dzornes95
dzornes95's Avatar
go to take off starts to rev then pops out,if take off is real slow it will shift to 2nd fine...shifting is real quick
Old 03-10-2008, 08:45 PM
mjr46
mjr46's Avatar
I'd check fluid level first.. if fluid level is fine then tv cable adjustment is next step and after that if you still have a prob.. tranny may need a rebuild as it may be slipping.. but start with fluid level.. check running and at idle
mjr46 is offline
Old 03-10-2008, 08:47 PM
dzornes95
dzornes95's Avatar
Thanks again man
Old 03-10-2008, 09:20 PM
mjr46
mjr46's Avatar
No problem..good luck
mjr46 is offline
cr620
10-03-2022 10:18 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
MacSerio
09-27-2015 01:05 PM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: tranny popping out of gear
