Best injectors for setup????
RE: Best injectors for setup????
ORIGINAL: Hung Like a Stang
the thread could have ended there.
If you want to make full use of forced induction on a 302 I'd go 42lbers
ORIGINAL: PRO50SC
Go w/ 42's, a blow thru mass air from p-mass and upgrade the fuel pump to a 255 pump for a blower application. Then get a custom tune.
ORIGINAL: PRO50SC
I3atR!ce, the motor being stock makes NO difference. Mine is bone stock, Bolt ons only and I needed to run 42's. I had 30's, they just weren't enough. I'm actually speaking from experience, not just some random thought.
So long story short..... those 19lbs are holdin me back... correct??? Now if i wanted a mild street motor would i need to go any bigger than #30 lb. I know your all pretty set on 42lb but somethin tells me that might be over kill for my setup. I may be wrong . You guys definatly know your 5.0's. If i pick up a set up 30 lbs , what exactly am i going to need to go with it. (what could i get away with). When you say "tune" are you talking about with a programmer??? Thanks guys .
yes 19 not enough, 30 would be suffice...but the cost of injector and a mass air system isnt cheap, buy bigger like 42 calibrate mass air meter to the injectors and u will be fine..go with 255 in tank. fuel pressure 42 -45...so if one day u through more boost or some head and intake u know u will have enough fuel...better to be rich and lean out then run lean! far as a tune, have it dyno'd some guys say invest in a programmer. i on the other hand had a speed shop burnt a custom chip exactly to what i need and plugged it into my stock computer.. they can always reprogram it later..
http://www.suttonhp.com/store/item.a...ARTMENT_ID=296
thats what i did..so if u are not sure of what and how to properly tune ur car leave it to the pros, u can get a hand held and be confused and still have to bring it to them..the chip is simple...
BY THE WAY IF YOU REALLY WANT 30'S I'LL SELL YOU A SET THEY WERE USED FOR A MONTH AND I FOUND THE 42 WERE THE SMARTER THING TO DO...I ALSO HAVE A MASS AIR METER FOR THEM TOO.... LET ME KNOW
DanCam if you want to go 30#'s you CAN....then run an FMU but only if you have no future plans ofupgrading heads cam ever....otherwise just get the 42# so you buy them "once" and get a chip burned.....listen to Pro50 his car runs hard......
ORIGINAL: PRO50SC
I dont need my car to run like PRO50 i just dont want i running lean. I'm content with little or no horsepower gains as long as my car aint running lean. Now if I go with 30lb injectors and a calibrated mass air for the 30lbs , do i still have to get a custom tune or can i run it as is.....Thanks guys your really save my a$$.
You won't need a custom tune. You will need to run an FMU though. You should still have it dynoed to see where the a/f is though. You should also run an external pump to help w/ fuel pressure.
