Best injectors for setup????
I have a 1990 5.0 that i put a 10 lb vortech blower on. I have free flow exhaust but she likes to run lean. Its got stock injectors in it. Would going to 30 lb. injectors be good/bad for my setup? If so would i need to do anything like recalibrate or should i be good to go. Thanks
RE: Best injectors for setup????
agree go 255lph in tank, mass air meter does need to be calibrated to injectors go #42's good upto around 520+hp.
far as mass air meter i went with a ford lightning 90mm the nice thing is that if it ever went bad most ford dealers carry them and they are half the price of an aftermarket, larger then most too...but remember that u need a custom tune and make sure to tell them so they can do the data transfer worked great!
is the motor stock???? you might be able to get away with 30-36's on a stocker but if you've got better flowing heads then the stock e7s your better off doing what Pro50cs said. the 42's will give you enough even if you up the blower pully and the intake 255 pump is a no brainer. As with all blower setup... get a tune!!!! more power + better streetablity (<- is that even a word)
ORIGINAL: PRO50SC
Go w/ 42's, a blow thru mass air from p-mass and upgrade the fuel pump to a 255 pump for a blower application. Then get a custom tune.
the thread could have ended there.
If you want to make full use of forced induction on a 302 I'd go 42lbers
