wiring help!
wiring help!
im in the process of putting my car back together and its time for the wiring. i have a 90 4cyl and im putting my motor into it. i bought the computer and efi and injector harness of a 90 v8. do i need to change my 4cyl dash harness. and how can i double check that my harness will work before i put the dash all back together?
thanks gary
thanks gary
RE: wiring help!
I just went through this whole process, yes, you have to change the dash harness. My gauges and such would not work until I did the harness swap. Car should run fine after the swap. Not sure about checking before install, I switched mine and it ran fine.
RE: wiring help!
87-93 fox dashes should all be the same plugs. When i did my conversion i changed it anyways its work and all but i knew it would work for a fact and i had the whole car stripped anyways, the only thing that may differ is your steering colum plugs, but im not 100 percent on this i never did an auto swap but as for manual trans swaps you should be all set. my conversion was a 92 in to an 87 the only differance there is the air bag plugs thats it...
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
