HIGH idle
HIGH idle
My car Idles at about 2000 to 2500 rpm, i jus replaced the O2 sensors thinking that was the problem because before i had this problem my C.E.L came on and i ran the code saying i had a bad oxygen sensor. Installed them and i still have a high idle...ive checked for vacuum leaks with some stater fluid and i havent found one..what else could it be?
95 Mustang GT, BBK Headers,MAC C.A.I, custom exaust
RE: HIGH idle
i had a similar problem on my 87 gt and it wound up being a bad tps (throttle position sensor) but id check for a vacum leak again, you cant have any leaks from your mass air flow sensor to the throttle body check clamps and make sure your hoses are on properly. try to spray carb cleaner around the upper intake gasket and lower intake gaskets and listen closely for any idle changes. check your vacum hoses they can get bumped off. just grab some stuff and wiggle ive found quite a few problems that wau too. good luck
RE: HIGH idle
thats wut ive basically come down to ive been checking vacuum lines all day and i think the sensor jus took a dump luckily they arent too bad like 30 something bucks but illl go over everything again ...thanks for the input
RE: HIGH idle
Welcome to the bad idle club [:@]
I would say to first try to reset your base idle since you just replaced your O2 sensors....
If that doesn't work, there is a sticky on here somewhere with all the different methods to chase the idle problems.....Good Luck!
RE: HIGH idle
ORIGINAL: FASTBLACK
Have you tried adjusting the tps before you just go out and buy another one. Another thing to do is to take off your iac and tear it down and clean it throughly.
RE: HIGH idle
ORIGINAL: jwells5.0
I could try that not to sure on how to adjust it though.. but i have noticed if i unplug that sensor my idle drops considerably and then it will idle low for like 30 sec before it dies from lack of air
ORIGINAL: FASTBLACK
https://mustangforums.com/m_969165/tm.htm
RE: HIGH idle
ORIGINAL: CantStopTheFox...
