Can anyone help? I have a 87 GT with a GT-40 crate. Oil pressure has started to fluctuate at cruising speed/rpm. Stays steady at idle. Still using stock gauges (needle normally right in the middle, but now drops down and then rises). Suspect sending unit, but want to know if anyone has any other explanations.
Pickup may be sucking on bottom of pan due to not enough clearance...
May be sucking pan dry due to slow drainback or high vol pump exceeding capacity...
