Finally installed my 3.73 gears!!
RE: Finally installed my 3.73 gears!!
Should I go one tooth higher or lower? I have the purple speedo gear now and my speedometer is about 5MPH to fast. Should i go with the orange one which is one tooth less then the purple one or should I go with the white one which is two teeth more than the purple one? Any and all help is appreciated!!
ORIGINAL: BlueDemon
Hey guys I finally got my gears installed and WOW what a difference!! Am I correct in assuming(according to Steeda.com) that that color means that I had 2.73 gears in there? There was no # on the old pinion or ring gear so I wasn't sure what gears were actually in there.
and you might not be able to get any closer than 5 mph to being right on the speedo, so why bother if you know how much it's off now.
my car's speedo reads 42 at actual 35, 66 at actual 55 and 79 at actual 65. that's all ya need to know man. lol. just get used to ur speedo and it'll be fine. (i'm cheap and don't spend money unless 100% necessary) plus my motors got about 200k on it, so the odometer doesn't bother me either lol. it turns 1.35 miles per 1 actual mile
Figure8allday
08-22-2015 11:11 AM
inyadreems
08-21-2015 09:10 AM
