Just did H/C/I did i screw up?
Old 03-18-2008, 03:16 AM
jerod187
jerod187's Avatar
Default Just did H/C/I did i screw up?
hey guys ive never done this before and i just wanted to know if everthing sounded good so far? i put a new holley systemmax 2 cam in with new timing chain, some ported polished, 1.94 and 1.6 valves, with heavy duty springs and retainers in and used energizer roller rockers,
my procedure, turn piston to TDC and adjusted the proper rockers then rotated adjusted other ones and so on, but i tightened the rockers by hand untill the push rod had slight resistance the tightened it 3/4 of a turn for each one but i didnt measure the pushrod length i just used stock ones, does this sound ok?
jerod187 is offline
Old 03-18-2008, 03:33 AM
67mustang302
67mustang302's Avatar
Default RE: Just did H/C/I did i screw up?
Stud mount? You should check geometry per the manufacturer's procedure for whoever made the rockers.
67mustang302 is offline
Old 03-18-2008, 03:35 AM
jerod187
jerod187's Avatar
ya theyre stud mount
jerod187 is offline
Old 03-18-2008, 09:43 AM
my77stang
my77stang's Avatar
i go 1/2 turn myself but 3/4 should be ok. you do need to look at the tip of the rocker and see where its touching the valve stem when its closed and when its open. you should be just above center of the tip of the valve when closed and just under when its open.
my77stang is offline
Old 03-18-2008, 01:48 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
you need to use an adjustable length checker for apropriate length to determine correct geometry or risk damaging guides /valve tips and or rockers
mjr46 is offline
Old 03-18-2008, 01:50 PM
joeymustang
joeymustang's Avatar
turn it on...i think you'll be fine
joeymustang is offline
Old 03-18-2008, 02:28 PM
PJC Racing
PJC Racing's Avatar
ORIGINAL: mjr46
+1
PJC Racing is offline
Old 03-18-2008, 04:58 PM
jerod187
jerod187's Avatar
i like the one better, lol because everything is already together turn it on...i think you'll be fine
jerod187 is offline
Old 03-18-2008, 05:07 PM
LTnone
LTnone's Avatar
ORIGINAL: joeymustang
Was that sarcasm? [&:]
It would be in your best interest to get an adjustable rod and make sure you're not going to have shiny parts colliding with one another. They aren't expensive, either. As for adjusting the rockers, that should be fine. The general rule is 1/2-3/4 turn past zero lash.
LTnone is offline
Old 03-18-2008, 05:39 PM
aode08
aode08's Avatar
ORIGINAL: jerod187
take em off one cylinder, put a black permanent marker circle on the valve tip stem(covering the whole tip,
then , do as you did, adjusting the two rockers, keep turing the engine over by hand or use the starter.
Note that the circle should have a narrow line in the CENTER of the stem, where it wore off the black marker.
aode08 is offline
Quick Reply: Just did H/C/I did i screw up?
