cam swap info
RE: cam swap info
i know its not the f/s forum but if you do look into the explorer intake i have one along with the tb. pm me if your interested. i was going to use it but the cam i got is much bigger then i thought so i will use my typhoon intake instead.
RE: cam swap info
ORIGINAL: jeepraider06
PjC Racing thanks for the reply. To tell you the truth I really don't know what type of studs are going to be on the heads. In you opinion which is the best to use, the stud mounts or pedistal. Also to measure for the correct pushrods I will need to get an adjustable pushrod correct. Again thanks for all the replys, sorry if I'm asking alot of questions, its just that I'm 19 and trying to build a really strong motor with out cutting any corners. Also any type of suggestions that you have that I should do please just let me know.
Thanks.
Thanks.
don't bother converting it over to stud mounted, I don't think it would be worth the hassle in your case
RE: cam swap info
Thanks.
Thanks.
RE: cam swap info
Thanks to all that have replied to my many questions. Again I have a question, when I get the heads from thumper (I think) they will have the stock valves. If they do will I need to check the valve to piston clearence.
Thanks
Thanks
RE: cam swap info
Stay away from Proform, never used them but I have been instructed not to use them by a reputable cam grinder. As a matter of fact he sells some good rockers at a decent price, http://www.camshaftinnovations.com/he does not have them listed on the site so will have to email him, but first find out fromThumper for sure if your heads are going to stud or pedistal mount before you contact CI.1.6's will be fine, but if you go with the B303 cam I would get 1.7 rockers.
RE: cam swap info
Thanks
Thanks
junior04
09-28-2015 10:53 AM
