C-4 question
C-4 question
i am going with a c-4 in my 393 powered mustang, my problem
i have a friend with a used c-4 he would sell me for $75 it is in need of a rebuild.
i need this tranny to withstand at least 600hp, would it be cheaper to buy this tranny and have it built to withstand my HP requirements,
or would it be better to just buy one already built from PA or redneck.
also the one my friend has is a pan fill, the ones from PA and redneck are case fill. does this matter at all?
will they both fit in my stang? which is better, and why?
thanks
thanks
RE: C-4 question
if you can build it yourself your cheaper to do so. that being said, PA has some quality transmissions at a pretty damn good price.
i bought my all my parts from a large seller on ebay and had my buddy who owns a local tranny shop assemble it (paid 100 bucks for assembly), in the end i spent 1000 bucks (counting converter from edge racing) so i saved a little bit but you might not be able to get it built locally for that price
RE: C-4 question
there is no real diff. in the 2 trans other then one is case fill and the other is pan fill there is more room for headers and the bell with the case fills cuz you can run the small 157 tooth bell. but the pan fillso they say is stronger due to the way the case is made. but C-4s don't have case strength problems anyway. PA use to use the pan fills backyears ago. I like the case fill over the pan filljust for the extra roomyou get.
RE: C-4 question
the pan fill is 164 tooth only.You can bolt a small bell on the case fill but it will look strange(but works)and you will need longer pump bolts cuz. the case fill bells bolt to the transusing the pump bolts and the pan fill uses bolt around the case.I ran long tubes with our old pan fill trans before it ate it self up I had to move the o2s to the out side of the collector mine were facing in other then that they worked.
RE: C-4 question
uedlose, i will keep that in mind.
if i happen to buy this tranny from my friend. how hard is it to rebuild, if i bought a book or something could i do it myself? does it require any special tools? or should i have it done by a professional?
RE: C-4 question
ORIGINAL: worm2500
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
