GT40 iron or TW
Old 03-18-2008, 06:52 PM
91lx50udlose
91lx50udlose's Avatar
Default GT40 iron or TW
I have my new shortblock assembled and am ready to bolt the heads on my motor is a stock bottom end rebuild e303 trick flow street upper/lower and bolt ons my question is should i bolt my gt40 irons just redone and home ported with 1.7rr which i already have or should i buy Trick flow Tw heads which i will have to buy new rockers (1.6's)as well it will cost me about $1500 do get the heads rockers and pushrods is it worth the money to buy those heads or just use what i have? what kind of power difference between the twois it really worth the swap on a stock bottom end 302? also i will be using the e303 even if i switch to the tw heads
91lx50udlose is offline
Old 03-18-2008, 06:59 PM
last50gt
last50gt's Avatar
Default RE: GT40 iron or TW
i would fork over the cash and buy the trick flows. i believe they will put out about 40 more horses and they are lighter and an added bonus is they will match your intake
last50gt is offline
Old 03-18-2008, 07:02 PM
91lx50udlose
they will make 40 more hp than the gt40's even on a stock bottom end?
Old 03-18-2008, 07:24 PM
91lx50udlose
anybody?
Old 03-18-2008, 07:26 PM
Joel5.0
Joel5.0's Avatar
Are they worth it over the GT40 irons......yep...... the only limiting factor you will have, is the E-303 cam. LMK
Joel5.0 is offline
Old 03-18-2008, 07:30 PM
91lx50udlose
i was just thinking that only on a 302 it wouldnt be but MAYBE 20-25hp on a real good day
Old 03-18-2008, 07:37 PM
50Stocker
50Stocker's Avatar
Don't think that number is quite right, 40 hp between the two....
Depending on how they are ported and polished GT40P's are a 40-50hp improvement over stockw/ 1.7's. An old Mustangs Unlimited catalog I had ('99) advertises Edelbrock's performer 5.0would add 70 hp (that is obviously a flywheel rating otherwise you wouldn't see so many people struggling to get to 300 rwhp with h/c/i), and Trickflow would be right up there with them.The P heads are a little higher compression, than the regular gt-40's.
We don't know what you did to them, the Trick Flows will probably give you more power out of the box, and the springs will run with that cam etc. But then again people run some impressive quarter times with worked GT40 irons.
You could always proceed with your heads with the home port, and then if that isn't good enough upgrade, especially if thethe tax man is going to be nice to you this year.
50Stocker is offline
Old 03-18-2008, 07:48 PM
OneFine89Mustang
OneFine89Mustang's Avatar
trickflow for sure
OneFine89Mustang is offline
Old 03-18-2008, 07:57 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
TF'S WILL outperform the gt-40's anyday
mjr46 is offline
Old 03-18-2008, 08:53 PM
Joel5.0
Joel5.0's Avatar
However...... don't make the mistake of "blaming" a component for not performing as expected. Keep in mind that no single part determines performance..... it's the combo that determines that..... and in your case, the E-303 would be the "weakest link"..... if you choose the TFS heads route.
Joel5.0 is offline
Quick Reply: GT40 iron or TW
