Rear Spring Question
RE: Rear Spring Question
im not a mechanic like i said but they are so easy to change that it might be worth giving it a shot .....if there not going to work you will notice immediatley ....however you might want to wait for another post ive been on this forum for like an hour lol but i would do it if you need to...but thats me
the 4 cylinder springs are a little bit weaker than the GT springs. Most people put them on there for the hell of it because they promote good weight transfer(launches) and give a little bit of a drop due to the extra weight on the gt's(lx 5.0's also)but on the downside, your car will roll more in the turns. If you want more of a drag setup they're fine, road racing, then they aren't great at all.
ORIGINAL: 302f150
Ok Ive started removing the rear springs. Ive got the swar bar off and the nut off of the bolt going through the lower arm. I put a jack under it to try and remove pressure but I still cant get that damn bolt out. Is there a easy way. I sprayed the hell out of it with WD40 and I still can't get it to move. It the only thing holding me back.
