tps voltage question
RE: tps voltage question
Mine is at .99, and it still idles like sh*t[:@]
But here are some good directions:
http://www.muscularmustangs.com/tps.php
If that doesn't work, the rest of the article has some great info for chasing the idle.....Good Luck!
Base Idle Reset Procedure
No..... any voltage reading between .7 - 1.1 vdc will work fine. The computer does the rest.
you should do your tps...then check iac and adjust idle...then redo the tps then reset the computer
anywhere from .950-.990 is fine really...it's the rare .750 stockers you wanna change
