Quick question about gaskets and heat spacer.
Do I need two gaskets when using a phenolic heat spacer? or can the spacer act as a gasket for the upper/lower itself. BTW all my EGR is blocked.
RE: Quick question about gaskets and heat spacer.
I would use two gaskets on it myself to make sure I didn't have any vacuum leaks.
If i try it without 2 gaskets and its not leaking, can i be confident that will work?
use gaskets man use gaskets
lol dam, gotta get another one then...
I would us 2 as well.Get the job done properly the first time.This way you don't have to do it again.
i agree
ORIGINAL: mustang8719 I would us 2 as well.Get the job done properly the first time.This way you don't have to do it again. |
i have two with my heat spacer. two came with the spacer, im surprised you didnt get two
ebay ones come with 1 ugh
i just ordered one myself cuz my tall valve covers are interfering with the throttle springs...and they came with 2 gaskets. Does it make a power difference??.
