the rubber seal is just a dust cover to protect the bushing really....
the bushing seals it up
not true!!!^^^^^ the bushing is notthe seal the seal seals it the stock type seal had a extended portion that das a dust protector but inside that is the seal the seal that taps into the housing is the seal.....you may have rolled it when installing the driveshaft or knicked it or check your driveshaft and see if a groove is worn around it..if none exisists try a new seal from the dealer =oem
