Few questions ?????
Few questions ?????
Ok Adjusting the hood.. The front right hood is up higher then the other side but its not the stoppers it kinda seems like it wobbly from side to side as if the locking needs to be moved down word to pull the hood closer to the frame but i tryed and nothing you cant move the bracket or the locking part.. second is my car has 194k on the motor runs "ok" but has a poping sound when warming up if i rev it but after it gets hot it goes away plus under 1500 rpm it has a small hesitation when reving could this be my timing chain it has new tps throttle body egr and the other tube on the side of the throttle i think iac?? but any ways its all new what could be wrong
RE: Few questions ?????
run a koeo/koer test and make sure no hood hinges are bent and loosen at firewall to lower/adjust down and or at mounting surface on hood to slide side to side or back and forth and make sure the rubber stops on the core support are adjusted to proper height
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
