miss...stumble on acceleration
ok so i live in upstate ny...just got an 86 gt vert from california...compleately stock...86k original miles.my problem is...when i accelerate usually under load...going uphill the car seems to miss or stumble a bit in 3rd and or 4th gear....it doesnt feel like tranny...its an auto...but feels more like ignition cutting out for a split second....kinda jerks quick but keeps moving....the plugs look ok..also after its warmed up it idles poorly...any ideas?
RE: miss...stumble on acceleration
most likely spark like you think, possibly vac
what plugs are in it ? don't use platinums, use cheap coppers gapped about .045"
.052" is stock gap, but if your ignition is weak it might not make it. close tham way up to check it...like .035"-.040 i use .042" for all the time but i spray too.
also do the cap,rotor, and wires....if they look new...make sure they are all "snapped" on good and double check the firing order.
after that look to the coil....but doubtful
also while your in there...look for brittle vac lines that may have broken
I would agree with nitrous_bob, I had the exact sympton but it turned out to be one of the connectors going to the coil. This was an odd one and self induced but the symption was just like what mine was doing, look over the coil, cap, rotor, plus and wires.
i think you are all right...when the guy told me ALL ORIGINAL i guess he really meant it! lol...looks like the original wires,cap ,rotor...it even looks like the original exhaust!...i will do a tune up and see what happens...thanx for all your input
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Offendant
09-23-2015 07:21 PM
09-08-2015 11:50 AM
zanemoseley
09-06-2015 12:58 PM
