I hate breaks
I hate breaks
Trying to get the stang all track ready for this weekend. my brakes for some reason are acting up. start the car and at idel i have plenty of pedall when i start driveing the car and try to stop i dont have that great of pedal it almost's goes to the floor. i checked break fluid its full and nice and clean....
RE: I hate breaks
The other thing i noticed was that on the driver rear side i took the drum off and theres a small cable inside that is broken..Not the ebrake cable..so im guessing i need a new spring kit do think that could be the problem
RE: I hate breaks
That's for the self adjuster. Start by putting some new drums on and bleeding. If the pedalwill still eventually go to the floor with constant pressure with no leaks - you likely have a bad master cylinder. Lucky for you - it is a cheapeasy thing to replace and will give you a great opportunity to change out your super nasty half-waterteenage brake fluid!
Worst case scenario - a Hundred bucks, a case of beer and a half a day later you got new shoes, a new master and fresh fluid front to back.
jwog666
12-27-2021 08:09 PM
treesloth
09-28-2015 07:03 AM
ccdguy
09-19-2015 05:20 PM
