Thermostat question
Thermostat question
My coolant temp is usually a little over 180 degrees once the car is fully warmed up...as measured by my Autometer gauge. If it's a hot day and I'm running the A/C, the temp may reach 195-200, but that's the hottest it ever gets. Even then, it will only stay that hot for a minute or so, and then the temp drops back down near 185. The temp seems to regulate itself to be a little over 180 most of the time. I'm wondering if the guys who changed my cooling system may have put in a 180 degree thermostat instead of the stock 195 degree unit. Given the running temperatures I've mentioned, does it sound like I have a 180 or 195 degree thermostat? Thanks.
RE: Thermostat question
I thought stock was 192? If your ok with the temp i would not be concerned with which one they put in there. I would imagine though that they put the stock one in there unless you specified differently, the 180' is usually a few bucks more.
Hmm.. It sounds like you have a 180 is in your system. In a 195 setup it usually hovers in the 192-195 range.
I have found that with a good radiator the range you are seeing is usually the setting of the therm.
FAST... You are right. Stock is 195.
G
G
Thanks for the replies, fellas. Is it 192? My mistake. At any rate, if there is a 180 degree thermo in there, I want it out. I've learned that, with iron engines, you want to keep the temp near 195 to minimize engine wear. I have to change my thermostat housing gasket, and I'm thinking I may just replace the thermo with a 192 just for good measure. Is the rating of a thermostat displayed anywhere on it?
Also, my entire cooling system is only like a year old. Is it possible that I do have a 192* thermo, but that my motor is just runningsuper-cool?
I once though a cooler engine wore down faster, but a few mechanics, and a friend who is a metallurgist told me that the temp has more to do with emissions than with wear and tear.
Metal expands as it gets hotter, and so on a hotter engine the tolerances are closer. A good oil prevents the wear and tear.
A cooler engine is more likely to, due to the settings of the 'computer', run somewhat rich, and produce more hydrocarbons.
G
G
ORIGINAL: 89GreyStang
G
G
I could be wrong on the thermostat since everyone else is saying 195. I went to the parts store to get one for my 351 block since i'm currently not running one and they said 192 was stock. I'm not trying to hijack your thread but i do have a question. My car runs very rich below 3k rpm's, as you can see i have no computer and also no o2 sensors, would a stat help with the rich condition. I've done all the adjusting and changing on my carb that i can do. I only get about 6 mph and would love if i could sqeeze 10 out of it.
ORIGINAL: FASTBLACK
Ship, thanks for the info.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
