cams and smog....
RE: cams and smog....
ORIGINAL: 90Mustangfan
No actually the only reason the e passes is because of the carb number. I will pass with the B if I tell the guy its stock cam. he wont look for the carb number, so it B for me.
Changing the cam out would be a lot of work if it fails the test.
I just talked to a good friend of mine and he said that the B will pass, there is only a slight difference between the B and the E. But yea the E... thats the only reason why it passes is because of the Carb numbers. The b will pass if you tell the guy its a stock cam.
yea well i have the fcam i should have thought about smog before i bought my cam and other nonsmog legal parts if it doesnt pass smog here in CA o well looks like ill just have to register the car in mexico and drive around with a yellow license plate.
junior04
09-28-2015 10:53 AM
