tha five ho wants 2 turn off
ok soo ever since i did the under drive pulley swap and smog delete and removed the a/c my car feels like it wants 2 shut down in low rpm's ooh and its a auto but when it wants 2 shut down i put in N and the engine spins fine any ideas????
RE: tha five ho wants 2 turn off
either way you need to plug off the lines..follow them back to where they plug into the intake and un plug them ...lay to side and cap of intake port where they go= easy
if you removed all the smog..I assume you removed the thermactor air diverter valve and bypass valves that connected to smog pump above passanger side header..and to those valves were two vaccum lines that go to the TAB and Tad selonoids..both have two ports.....one for source vaccum and the other goes to the valve to activate it....from the selonoids the lines go to intake I believe..if you want you can cap of selonoid ports..whatever is easiest
lincolnshibuya
12-08-2015 04:37 PM
breaking
10-02-2015 01:27 PM
logan409
09-26-2015 07:43 PM
