vibration problems still.
I had another thread, but it went cold...
This is really getting old. I replaced my U-joints, harmonic balancer, engine/tranny mounts, had my driveshaft rebalanced. I replaced my clutch and flywheel with new ones. The clutch was from Autozone and Spec 2 clutch kit. My tensioner is bad, but I can't see that adding vibration. Smog delete.
If I hammer the car it vibrates at about 4,000 rpms and it stays the same til I shift at 5500. If I hammer it in nuetral it revs up fine but when it comes down it shakes and vibrates. If in nuetral I rev it slowly I get a vibration in the lower rpms (like 1,000-1,500 rpms not exact but close).
RE: vibration problems still.
As long as its not a daily driver f*** it just drive the hell out of it. My brother ran his with a bent rod for easily 30,000 miles and just decided to swap it after the 200,000 mile mark. When you get the money for it go get a 351
It had the dowels already on it. I noticed some gray plastic piece that was broken. I pulled it from my bellhousing. It is my DD, but I have a Suburban and a LeSabre so I do have other options. The gray plastic piece looked round and smooth on the outside and looked as if something screwed into it, it had internal threads. I didn't see this piece until i looked under my car a couple days ago, I never noticed it when I was reassembling my car.
lost it.
I also forgot to mention that when i removed my driveshaft to take it to the shop I started my car and the vibration was still there. Balancer helped but not the solution.
What is the general consensus on how to narrow down if a vibration is engine, tranny or driveshaft or balancer?
Omgitsa88Stang
10-05-2015 07:33 AM
ccdguy
09-19-2015 05:20 PM
LivingInThePast
09-16-2015 12:20 PM
