Delete Smog Pump....What to do with hoses
Old 03-28-2008, 08:32 AM
onebadyfz450
onebadyfz450's Avatar
Default Delete Smog Pump....What to do with hoses
im in the middle of re-routing my belt with my new Mac underdrive pulleys, now when i take off my smog pump and bypass it, what do i do with all the hoses coming off of it.
maybe its not alot coming off the smog pump, but i dont wanna (plug) the wrong hose or something and make something go wrong.
im trying to take it to the track this weekend....
any info would really help.....[/align]
onebadyfz450 is offline
Old 03-28-2008, 08:42 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: Delete Smog Pump....What to do with hoses
remove all hoses/ thermactor air bypass valve and diverter valve and cap off vaccum lines to selonoids and plug the gulp valve/check valve that goes on the tube that connects to the back of the heads
mjr46 is offline
Old 03-28-2008, 02:55 PM
nitrous_bob
nitrous_bob's Avatar
you can completely eliminate all of them if you want...the piping that goes to 2 steel pipes (h-pipe and back of heads) you just need to cap off the end coming from the h-pipe, and then plug the 2 holes on the back of the heads w/ "thermactor plugs" they are a threaded insert.
bolts will work too, but have to be right lemgth or it won't seal.
ghetto way is cut the "y" pipe off, flip them around and use rtv...then reinstall on the opposite head...that way the blocked part goes over the hole, and you reuse the mounting bolts
and you can't see them anyways
nitrous_bob is offline
Old 03-31-2008, 03:14 PM
onebadyfz450
ORIGINAL: mjr46
i did this but on the check valve that connects to the head. i just caped it off with a big bolt,my smogs still there, but i bypassed it and my belt went from a 105 1/2 to a 90.
now should i unbolt the smog and remove the whole pump
Old 03-31-2008, 06:31 PM
mjr46
mjr46's Avatar
^^^^^you can do just that
mjr46 is offline
Old 03-31-2008, 09:01 PM
ckyguy68
ckyguy68's Avatar
I used a 3/4" vacuum cap for the line that goes to the heads. Its easier than a bolt and looks a little cleaners too.
ckyguy68 is offline
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Teddi
09-29-2015 12:24 PM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
Quick Reply: Delete Smog Pump....What to do with hoses
