heater core?
heater core?
i have an 86 gt vert....im guessing my heater core is leaking...when i turn on the defroster i get a fog or smoke coming out initially then the window gets fogged or hazed...i was wondering if it is a small leak if the bars leak stuff will or might fix it...thanx...john
RE: heater core?
Does it smell like antifreeze? You can take a white paper towel orcloth and wipe around the haze seeif it has a greenish tint to it..... but not sure a leaking heater core would cause this, does it also happen on the cold setting? Every time I have had a heater core go out on me I get a puddle of coolant in the passenger side or a puddle on the ground and the smell.
The good news is I think on your 86 the heater core is easy to replace, right behind the glove box and no need to remove the dash butI maybe wrong.
RE: heater core?
it is the heater core.....disconnected and bypassed it and no more fog...also cleared up my overheating problem...did a search and found that some people have had a small leak in the heater core which would allow air to be sucked in thus making the cooling system airbound
Seanam
10-04-2015 10:15 AM
Calizic
08-28-2015 01:46 PM
