Radiator questions
Radiator questions
I got a 87 mustang GT that is bored .040 over. It is running warmer than its supposed to around 195 to 200 after about 30 minutes of cruising. Im wondering what i can do to make it cool better its got a big electric fan on it already. Im wondering if a 1 row all aluminum radiator will work to keep it cool like its supposed to be. I am also not running a t-stat. Or if anyone else knows of a way to get an engine to cool better im open to options.
RE: Radiator questions
here is deal. put the thermo back in. you have so much flow going through there that the coolant doesn't have a chance to cool down!! the thermo stat also slows down the flow so the air has a chance to cool down the system. i have a griffin 3-core aluminum. Works great for the most part. car sticks around 160 until i hit 10 lbs of boost... then it might jump up to 180 are you still using the AC?
Yeah i would say thermostat also, you may also want to find a radiator shop toclean and check your rad for build up or blockages. I have heard leaving the tstat out can break up some of the scaling and mineral deposits in the system and block the radiator.
EDIT: you still have your fan shroud on as well right?
treesloth
09-28-2015 07:03 AM
