running serpentine belt
i'm needing to run my alt, water pump,p/s and tensioner pulley, i don't have under drive pulleys i'm missing the a/c delete pulley is there a way i can run with out the delete pulley, someone sad i could turn my tensioner pulley around if i had underdrive pulleys but wasn't sure about regular pulleys, has anyone done this if so how and what size belt?
RE: running serpentine belt
I cant find it now, but someone posted a good pic with the diff configs for the belt and included the sizes. It was in the last couple days I believe.
EDIT: I found it, mongolchuck posted this link http://www.cjponyparts.com/NewTech50Belts.aspx in the older thread https://mustangforums.com/m_4864157/tm.htm, hope it helps.
thanks for the info my trouble is that my car came with a/c it's been removed so my p/s is still down lower i was wonder if there is a way to run my belt with out moving the p/s or getting the a/c delete set
in all the different ways they have on that site none of them will work for what i wanted to do they do have one with just alt, p/s, w/p but the p/s is up top
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
