heater core
Old 04-02-2008, 07:32 PM
rebelcowboy
rebelcowboy's Avatar
Default heater core
has anyone ever used stopleak to fix a heater core,i replaced mine about 2 months ago and it is leaking again,i dont have a f**kin clue as to y,but it just leaks when u get on it hard,it is just drippin,i used stopleak in my pickup when my timim cover was leakin and it stopped it.i dont want to pull my dash off again.
rebelcowboy is offline
Old 04-02-2008, 07:39 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Default RE: heater core
don't use stop leak..it clogs everything up in the long run it creates more probs then it solves...seen it one to many times clog crap up
mjr46 is offline
Old 04-02-2008, 07:43 PM
rebelcowboy
well the kind i used on my timin cover was little copper looking flakes not that big pieces,it sealed my timin cover no problem,
Old 04-03-2008, 05:33 PM
aode08
aode08's Avatar
where is it leaking from?
aode08 is offline
Old 04-03-2008, 08:49 PM
capri debris
capri debris's Avatar
List of reasons why new heater cores leak:
1. Faulty right out of the box. I always air test them with some hose, a "T" fittingand a gauge.
2. Installer being too rough when putting the hoses on. Bending the necks will make them leak where they attach.
3. Old motor mounts. The engine rocking under power tugs on the fagile necks via the hoses.
4. No flow restrictor installed in the inlet hose. This lets allows too much pressure in the heater core.
5. A poor ground in the electrical system. Stray electrical currents will "eat" the metals of the radiator and heater core.
6. Radiator cap rated at a higher PSI than neccesary. This allows too much pressure to build up in the entire cooling system.
And like stated above by a wise member... stop leak is the devil in a bottle. DON'T USE IT!!!
capri debris is offline
Old 04-03-2008, 10:14 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
Replace it.....not hard, but time consuming.....and it only costs like $20.....
Here are some directions........I did it twice [:'(]
http://www.mustangmonthly.com/howto/5652/index.html
CantStopTheFox... is offline
Old 04-05-2008, 06:06 AM
mustang86cars
mustang86cars's Avatar
+1 cantstopthefox
mustang86cars is offline
djbigskrilla
09-20-2022 01:04 AM
mrtrodonet
09-19-2020 03:12 PM
Seanam
10-04-2015 10:15 AM
Calizic
08-28-2015 01:46 PM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: heater core
