torque converter
i was going to buy a torque converter, but online it said that there was two kinds, a pan filled and a case filled, what is the difference, and which one should i buy?
RE: torque converter
sounds like C4, well if your dipstick go's in the side of the pan that is what you need if it is in the case you need that one.. i bet unless you are running a big block you need a case fill. BUT WAIT you also need to know bolt circle for the flexplate;)
the most common c-4's that people have and that are sold are case filled..easy to spot:D
yep, case filled are usually in vans some trucks to though... the spline count is different
also a tip don't buy a B&M convertor.
